97rs4life - FirebirdV6.com/CamaroV6.com Message Board
97rs4life
  • 97rs4life
    can you please tell me what wire to put the window switch to? the tach wire or w/e
    Re: 97rs4life
    nope. :p
    are you trying to get a tach signal or the tps signal?
    http://www.bowtiev6.com/
      Re: 97rs4life
      tach for the window switch?
        Re: 97rs4life
        people have used the coil pack wiring for that as well as the cam sensor as well.
          Re: 97rs4life
          where is this? whats it look like???
            Re: 97rs4life
            http://engine.firebirdv6.com/38pin.html
              Re: 97rs4life
              uh? what pin and what color wire?? bottom pcm thing im guessing?
                Re: 97rs4life
                on the clear plug of the pcm (bottom one)
                second white wire...pin #8 is what you need since you have a 99+ car
                  Re: 97rs4life
                  that dident work??? it is wastespark correct? and the dynotune window switch, you put wastespark and 6 cylendaars right?
                    Re: 97rs4life
                    you tried #8 already? That is usually what people use to get tach signal on 99+ cars. My 97 is different than yours
                      Re: 97rs4life
                      try pin 54 white wire think thats it to.
                        Re: 97rs4life
                        its the top pcm blue bank.
