ls1 kit on v6? - FirebirdV6.com/CamaroV6.com Message Board
ls1 kit on v6?
  • ls1 kit on v6?
    can a kit from harrisspeed for an ls1 ect platform be used on a v6 car? i thought nitrous kits were some what universal.
    Re: ls1 kit on v6?
    nitrous kits are universal unless they have a plate or something instead of a nozzle. As long as it uses a nozzle it will work on a v6
      Re: ls1 kit on v6?
      I had thought V8 kits use a bigger line for the nitrous and fuel, this would throw off jet sizing a bit, ours 4an and I thought V8's where 6 an, I could be wrong though. I hope someone can give some help on this.
        Re: ls1 kit on v6?
        It will work. V6 and V8 base kits use 4an. I'm unsure if that's exactly how Harris Speed works, but if it's a nozzle, you're good to go. 6an kits are usually a price step up.
          Re: ls1 kit on v6?
          Should work just fine.
          1997 Camaro RS A4
          2006 Chevy Colorado
          2003 Kawasaki Ninja ZX6-R
            Re: ls1 kit on v6?
            im running the hsw ls1 kit. you just have to change how the solenoids mount
              Re: ls1 kit on v6?
              The Kits with the 6AN line are for 300 plus horsepower and two stage systems.
                Re: ls1 kit on v6?
                I guess that clears it up for me, nice to know you can use V8 kits.
                  Re: ls1 kit on v6?
                  http://www.harrisspeedworks.com/shop...cat=365&page=1
                  thats the kit im looking at, i beleive it has 4 an line so im guessing its ok for us to use
                    Re: ls1 kit on v6?
                    That'll work, but just make sure it's wired up correctly.
                      Re: ls1 kit on v6?
                      any advantages to using a plate kit? I remember ZEX recommending you mount the nozzle about 6 (?) inches away from the TB. Does plate give you enough room?
                        Re: ls1 kit on v6?
                        a plate kit is made to work with an ls1 intake, so no it is not going to work on a v6. A plate sprays the nitrous and fuel in a pattern to mix it, works great on ls1 car and lt1 cars. It would be a wet kit if it is a plate.
