Somone post me up a good link to a nitrous kit.....im looming for one around 500......i want it to be safe though
Nitrous links??
Re: Nitrous links??
good starter kit would be the NOS 05175
http://www.gvperformance.com/store/i...d&productId=34
That would be a dry kit which is going to be safer and the way to go for just starting out
Re: Nitrous links??
Dry won't blow your intake manifold through your hood. Ask me how I know. Wet is "safer" because it's less prone to detonation. In my experience, dry is the way to go. Our intakes do not flow fuel well at all. I've yet to see anyone run much better wet vs. dry. Mattyacks, go with the cheapest dry kit you can find. You want to be really safe? Pill it to 100hp, throw a set of NGK TR-6 plugs in it, and only race it on a minimum of 93 octane (I prefer 100 octane).<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: Nitrous links??
Originally posted by zpwn06 View Postdry is safer than wet? I thought it was the other way around.
Re: Nitrous links??
Originally posted by Bird_Of_Prey View PostYou want to be really safe? Pill it to 100hp, throw a set of NGK TR-6 plugs in it, and only race it on a minimum of 93 octane (I prefer 100 octane).sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Nitrous links??
50 shot? Really? You can't even feel that hit. Fuel pump is optional. I ran the stock pump alot without a hiccup.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: Nitrous links??
Originally posted by Bird_Of_Prey View Post50 shot? Really? You can't even feel that hit. Fuel pump is optional. I ran the stock pump alot without a hiccup.
Re: Nitrous links??
Originally posted by bottlefedv6 View Postyes really, you want to dial in the nozzle tuning first and make sure everything is working properly before upping the shot. Then once you know everything is working good and there is no KR you can up the shot. 75 shot just needs the plugs. 100 shot you would want fuel pump.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
