i need advice - FirebirdV6.com/CamaroV6.com Message Board
i need advice
  • Re: i need advice
    here it is. note the part that says "thermostat, wiring blah blah blah all included"
    http://store.summitracing.com/partde...5&autoview=sku
    too late to call summit, will do it tomorrow =(
    • Re: i need advice
      ok i figured it out... it's only the element that comes in the package... =(
      it's easy to blame my ignorance, but being new to nitrous and seein on that same page "thermostat,switch,wiring all included" kind of led me to believe it would all be in there!!!!!
      FFFFF*****CCCCCCCCCKKKKKKKKKKKK
      ok, i'm calm now. the thermostat costs 33$, but what else will i need, i can't find a switch kit anywhere. can someone please tell me how to jerry rig a switch or find the kit i need to buy.
      thanks
      • Re: i need advice
        The thermostat should cut the heater off once it reaches the right temp, so all you need is a toggle switch to turn that on. No big deal :)
        O, and check out this site: Nitrous Forum. Almost any question can be answered over there if it's nitrous related :)
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
        • Re: i need advice
          thanks.... what kind of toggle switch? 2 throw?
          • Re: i need advice
            just any standard on/off switch will work. You don't want a momentary one, you want one that'll stay on when on and stay off when off
            ~97 3.8L V6 Camaro~
            A few things
            • Re: i need advice
              hey man, you could have had your other stuff just as fast as I had the msd switch to ya, ha. just messing with ya. www.gvperformance.com for all your needs in the future. ;)
              http://www.bowtiev6.com/
              • Re: i need advice
                =( your prlly right.
                can u help me get the parts i need for this bottle heater??
                • Re: i need advice
                  You will need a relay as well. They are very important cuz bottle heaters use a ton of power. The good thing is that relays are only around $5. I might even have a spare one, I'll check my tool box tonight.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
                  2003 Kawasaki Ninja ZX6-R
                  • Re: i need advice
                    My heater is just straight wired off the on/off switch works good, used 12ga. wire , for safety though a relay is recommended. I also have a electric nitrous pressure gauge to watch the PSI of the bottle.
                    • Re: i need advice
                      i think i"m gonna just buy the kit and sell the heater but>>>>>so to jerry rig this heater i have right now, i need a switch with on/off, i need a bunch of 12 gauge wire, butt splices, a relay, and a ground and power supply.
                      heres some Q's.
                      where does the relay fit ino all this, this go inbetween the 12v source and the switch?
                      what power source should i use
                      • Re: i need advice
                        http://holley.com/data/Products/Tech...069-1-SNOS.pdf
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                        • Re: i need advice
                          thanks i get most of that now...
                          this is gonna sound reaaaaalllly dumb but is this just a normal relay that i use? if so where do the prongs go? and where do i put the relay.... i'm not getting the relay part of it...
                          • Re: i need advice
                            That's the same link I sent ya last night :P. A standard 35A relay will work; the harness plugs right into the bottom of the relay, and that's where the colored wires come into play. Like I said, swing by a store today and pick up one and the harness and a switch and you'll be set.
                            ~97 3.8L V6 Camaro~
                            A few things
                            • Re: i need advice
                              i get it, i have to buy a relay AND a harness for the relay.
                              but will the relay harness i buy have the same color wires as the one in the kit?
                              • Re: i need advice
                                dude, you have help on the install...i can explain and show it all to you while were doing it lol
                                Y87 Package
                                MANUAL CONVERTED, Pro 5.0 Shifter
                                Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                                MOGOB APPROVED!
                                BONE APPROVED!
                                VANBIBBER APPROVED!
                                KRISTEN APPROVED!
                                Vice Prez.
                                Team Black...TEAM EMO
                                Come on kids! Get a Calendar!
