ok i figured it out... it's only the element that comes in the package... =(
it's easy to blame my ignorance, but being new to nitrous and seein on that same page "thermostat,switch,wiring all included" kind of led me to believe it would all be in there!!!!!
FFFFF*****CCCCCCCCCKKKKKKKKKKKK
ok, i'm calm now. the thermostat costs 33$, but what else will i need, i can't find a switch kit anywhere. can someone please tell me how to jerry rig a switch or find the kit i need to buy.
hey man, you could have had your other stuff just as fast as I had the msd switch to ya, ha. just messing with ya. www.gvperformance.com for all your needs in the future. ;)
=( your prlly right.
can u help me get the parts i need for this bottle heater??
You will need a relay as well. They are very important cuz bottle heaters use a ton of power. The good thing is that relays are only around $5. I might even have a spare one, I'll check my tool box tonight.
My heater is just straight wired off the on/off switch works good, used 12ga. wire , for safety though a relay is recommended. I also have a electric nitrous pressure gauge to watch the PSI of the bottle.
i think i"m gonna just buy the kit and sell the heater but>>>>>so to jerry rig this heater i have right now, i need a switch with on/off, i need a bunch of 12 gauge wire, butt splices, a relay, and a ground and power supply.
heres some Q's.
where does the relay fit ino all this, this go inbetween the 12v source and the switch?
what power source should i use
this is gonna sound reaaaaalllly dumb but is this just a normal relay that i use? if so where do the prongs go? and where do i put the relay.... i'm not getting the relay part of it...
That's the same link I sent ya last night :P. A standard 35A relay will work; the harness plugs right into the bottom of the relay, and that's where the colored wires come into play. Like I said, swing by a store today and pick up one and the harness and a switch and you'll be set.
4 days ago
