Which wire is the tps wire? - FirebirdV6.com/CamaroV6.com Message Board
  • Which wire is the tps wire?
    im trying to install my zex dry kit but i cant figure out which wire is the tps wire, i tried googling but no luck
    Re: Which wire is the tps wire?
    car year makes a difference...need more info
    http://www.bowtiev6.com/
      1999 3.8 sorry
        got it all mounted
        still cant find this damn tps signal wire
          i think on my car (1999 as well) the tps wire i tapped was the green one on the throttle body. i can for sure find out tomorrow when i go home if your patient ;)
            lol alright thanks, i dont remember , and its raining right now, but i think there is 2 blacks,green,purple,yellow,and 2 grays, and orange or something
            but yes please get back to me lol
              not sure from the diagram which one it is, maybe you can read it better. My 97 is different
                hmm the font is so small, but it looks like the green wire screamin 99 thought it was is a ground
                  looks like it is the purple wire
                    Scrap the TPS switch and get simple microswitch. Mount it under your gas pedal. Problem solved.
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                    2003 Kawasaki Ninja ZX6-R
                      with the zex kit, im pretty sure you have to use the tps since its connected to the actual box.
                        And yet another reason I wont use Zex kits :P
                        Good luck with it and let us know when its hooked up and running.
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                          do you think it would be the purple wire, its labeled tp signal so im thinking thats the wire i need, just wanting a second opinion, everything else is ran ill make a video once its all good to go
                            i got it working, and im using it like a purge untill my plugs and wires come in
                              so you used the purple wire then?
