Re: MAP tuning
I dont suppose you would be able to splice to Mafs together and run them off the same table then? I would think it would be a nightmare to calibrate since you could never flow exactly the same amount of air into both Tbs...
The other option someone suggested was something like this...
The problem is, is the pipe going to each TB is the same size as the single pipe coming from the filter...to me I can't see how that would flow any better then a single TB...
