'96 PCM Removal - FirebirdV6.com/CamaroV6.com Message Board
'96 PCM Removal
  • '96 PCM Removal
    Anyone have a quick and easy way to remove the PCM for our cars? I've got it in storage right now and don't want to drag my tool box if it can be quick and painless. Also, if I've been reading other threads right. a '97 PCM can be plugged into a '96 without rewiring (as long as it goes 4l60 to 4l60 and gear for gear)? Thanks in advance.
    Re: '96 PCM Removal
    yes a 10 mm socket. thats it really. i think u might need one smaller size as well i forget though...to take it completely out
      Re: '96 PCM Removal
      oh and yes 97 is direct swap...i recently did mine. real easy
        Re: '96 PCM Removal
        Yep. Easy direct swap. Little bit of a pain to coax is out. It's easiest if you loosen up the cowl, but it's doable without.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Re: '96 PCM Removal
          The hardest part is putting it back in like said the cowl really can mess your hands up with some minor cuts/stratches. Make sure you know your clear and blue side for connections although even if mixed up they will not plug in the wrong connection.
            Re: '96 PCM Removal
            Gentlemen, thank you so much for your input. I think I'll get the reprogram at this point (being that it'll be free) and save up so that I can get HP tuners, then grab a '97 PCM and finally, finally, the project will be done. Thank you again. This has been a real help. :bowdown:
              Re: '96 PCM Removal
              no problem any time
                Re: '96 PCM Removal
                no to hijack but can i replace my 95 3.8 pcm with this
                http://cgi.ebay.com/ebaymotors/ws/eB...tab%3DWatching
                  Re: '96 PCM Removal
                  Already been there. Asking him on Ebay and waiting on the answer.
