1997 maro 3.8 engine what computer interchange with this car
what interchanges
Re: what interchanges
Originally posted by 97rs4life View Postanother 97 computer only
I was reading a site a week or so ago that had the entire compatibility list. Now I can't find the link and I need to pick up a cheap PCM to use while the PCM in my Firebird is mailed out for tuning.
If anyone else knows the site I am speaking of, please post the link.
Originally posted by Mark42 View PostThat is not correct. There is a list of all compatible PCM's by PCM number, year and model vehicle. I think Monte Carlo and Corsica PCM's work as straight plug-in's. There are many different GM vehicles you can get a PCM from to replace the one in your car, especially if you have an automatic. If you have a manual, you may have to "tune" it to bypass some codes thrown by not having the automatic wire harness connected.
Actually, there was someone else right on this site that did just that. Plug and play, not even from a Camaro into a Camaro.
Read this thread all about swapping PCM's:
http://forum.camarov6.com/showthread.php?t=63721
Here is the link to the list of GM vehicles that use the J2543 standard. There is a good chance that PCM's are swappable between these cars with the same motors.
http://www.cardone.com/English/Club/...01993-2008.pdf
that thread you linked talks about 3.4 and 3.1 computers, then someone lists the other years and everything under 1997 is 97 cars.
The pinouts are different when you go to newer years. You can't use a 2000 pcm in a 97 car without repinning it.
Not sure what the big deal is though, 97 pcms can be found easily. The next question would be does the OP have HPTuners?
