I have a 2000 camaro 3.8L. So I start my car up and it throws an engine light (p1221) and reduced eng pwr light code. I can only drive my car up to 15-20mph and my tach will not rise above 2500rpm. After several hours later, both lights turned off and my car drove like normal. Any steps you guys can suggest to troubleshoot/solve problem? Thanks
p1221 and reduced eng pwr light
Re: p1221 and reduced eng pwr light
yea something like that happened to me they told me it might be the MAF sensor, spent 150 on one and that wasnt it. There went my 150; for me it turned out to be the TPS so i had to replace the throttle body since there riveted in. Still have that MAF sensor around here.
Update: so I started it up this morning, the code and reduced eng pwr light came on when I went to put it in reverse; I shut it off and returned to it this afternoon and no lights.. I drove it around the block and it drove like a beauty.. I did an experiment and revved in neutral to about 5000rpm and both lights came back on and I couldn't go above 2000rpm and 20mph again.
Also, after turning the car off, I noticed there is a small high-pitched whining noise by the fan for approx. 2 secsLast edited by jkelley; 11-19-2009, 04:57 PM.
Originally posted by firebird19_99 View Postyea something like that happened to me they told me it might be the MAF sensor, spent 150 on one and that wasnt it. There went my 150; for me it turned out to be the TPS so i had to replace the throttle body since there riveted in. Still have that MAF sensor around here.
Originally posted by jkelley View PostAlso, after turning the car off, I noticed there is a small high-pitched whining noise by the fan for approx. 2 secs
Thats the TB motor holding the butterfly open for a few seconds before it turns off after turning off the ignition.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
I guesss this was never solved?Wait, Is that a V6 or V8?
