Fuel Trim - FirebirdV6.com/CamaroV6.com Message Board
Fuel Trim
  • Fuel Trim
    Was logging a run and for some reason my long term fuel trim bank 2 is at 16.4% even when it is idling. I even put the stock tune on the car but still my ltftb2 is still 16.4%. Can any one help me correct that?
    Re: Fuel Trim
    I use the injector fuel tables/PE tables to dial my lifts in works pretty good their at -2 at WOT.
      Re: Fuel Trim
      What I noticed is that at wot it stays close to 0% so I am thinking maybe I have a vac leak somewhere but I could be wrong. I used part of Russ K's guide to adjust the PE tables.
        Re: Fuel Trim
        You should be good if it is locking in at WOT.
          Re: Fuel Trim
          Is bank 1 close to that?
            Re: Fuel Trim
            Yeah bank one is close to that. bank 2 is the one that is really high.
              Re: Fuel Trim
              You've been resetting the fuel trims right?
              lmao, steve. I hate that way of tuning. I used the MAF table mostly with my wideband, but i've touched on the VE table. I need to learn more about tuning the VE because it seemed to have made a slight difference. That could be in my head though.
              Anyways, BOT. Have you changed your injectors? And mostly, what tables have you edited? And what's your setup anyways?
              TEAM C6V6
                Re: Fuel Trim
                I know, thats the only way I learned it , and it works well for me to dial in.
                  Re: Fuel Trim
                  lol, dude I have 42.5 injectors in there and couldn't get the damn injector table right so I set them straight across the board at 42.5 and said f it. It runs the best that way so, lol whatever works.
                  TEAM C6V6
                    Re: Fuel Trim
                    Injectors are stock. I did reset the fuel trims it goes straight to zero when I reset them but the problem is that after a few mins it start to climb to 16.4%.
                      Re: Fuel Trim
                      I heard the 42.5's are harder to tune than the 65LB injectors, so I could only imagine trying to dial them in.
                        Re: Fuel Trim
                        Yeah I tried asking around for some help but no one really had a straight answer.
                        TEAM C6V6
                          Re: Fuel Trim
                          If you don't have any exhaust leaks Causing your O2's to see a lean condition, you need to tune the MAF table.
                            Re: Fuel Trim
                            Just in case you don't have a wideband I'd highly suggest getting one. It makes tuning exponentially faster and easier when you set up the right histogram. The AFR error % histogram specifically.
                            TEAM C6V6
                              Re: Fuel Trim
                              http://www.hptuners.com/forum/showthread.php?t=25482
                              here's a post about injector tuning... seems like you're supposed to set the same across the board... the the turbov6camaro.... does that also
