Was logging a run and for some reason my long term fuel trim bank 2 is at 16.4% even when it is idling. I even put the stock tune on the car but still my ltftb2 is still 16.4%. Can any one help me correct that?
Fuel Trim
Re: Fuel Trim
I use the injector fuel tables/PE tables to dial my lifts in works pretty good their at -2 at WOT.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Trim
You should be good if it is locking in at WOT.Last edited by ssms5411; 01-02-2010, 11:23 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Trim
Originally posted by insaneABOT View PostWas logging a run and for some reason my long term fuel trim bank 2 is at 16.4% even when it is idling. I even put the stock tune on the car but still my ltftb2 is still 16.4%. Can any one help me correct that?sigpic
Re: Fuel Trim
You've been resetting the fuel trims right?
lmao, steve. I hate that way of tuning. I used the MAF table mostly with my wideband, but i've touched on the VE table. I need to learn more about tuning the VE because it seemed to have made a slight difference. That could be in my head though.
Anyways, BOT. Have you changed your injectors? And mostly, what tables have you edited? And what's your setup anyways?
TEAM C6V6
Re: Fuel Trim
I know, thats the only way I learned it , and it works well for me to dial in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Trim
Originally posted by ssms5411 View PostI know, thats the only way I learned it , and it works well for me to dial in.
TEAM C6V6
Re: Fuel Trim
I heard the 42.5's are harder to tune than the 65LB injectors, so I could only imagine trying to dial them in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Trim
Originally posted by insaneABOT View PostInjectors are stock. I did reset the fuel trims it goes straight to zero when I reset them but the problem is that after a few mins it start to climb to 16.4%.Last edited by bigbrian442; 01-02-2010, 03:48 PM.sigpic
Re: Fuel Trim
http://www.hptuners.com/forum/showthread.php?t=25482
here's a post about injector tuning... seems like you're supposed to set the same across the board... the the turbov6camaro.... does that also
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
