Another CASE Relearn question.... - FirebirdV6.com/CamaroV6.com Message Board
  • Another CASE Relearn question....
    Has anyone done a relearn by using this method in place of using a scan tool?
    1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees
    (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
    2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8-10 minutes until the engine reaches
    operating temperature.
    3. Cruise at 55 mph for another 5-6 minutes.
    4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
    5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary.
    Returning to 45 mph for 15 seconds in between deceleration cycles.
    6. Accelerate to 55 mph and cruise for 2 minutes.
    7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic
    trans.) or Neutral (manual trans.) with the clutch depressed.
    Re: Another CASE Relearn question....
    yea i tired that a bunch of times in october to pass inspection. it was kinda weird for me i had trouble setting all the sensors. step 1 worked consistently for me setting the O2 sensor heater. i reset them again and tried again and got most of them set (turned out i had a bad O2 sensor thats why i was having so much trouble) but another way i heard about doing it was to not drive over i think it was 3000 rpm. this worked for me as well.
      Why bother when it takes 30 seconds at a dealer? And they did mine for free.
      Raven
        Lucky dog! I had a hard time finding a dealer who knew what I was talking about. Printed the procedure off from Service Information and brought it with me to a dealer who said they could do it just to be sure.
        They charged $40 for the service. Just a labor charge for the time the tech was working on the car.
          cant u disconnect the battery for 30min and do the same thing?
            ABSOLUTELY NOT!!
            Think about it - how the hell would the PCM figure out the "Crankshaft Angle Sensor Error"???
            http://forum.camarov6.com/showthread.php?t=94511
            Raven
              ABSOLUTELY NOT!!
              humm thats what i get for not looking up what CASE means... sorry
                :spank: You should know better.
                Raven
                  haha agreed :work:
                  ban me now! jk
