swapping in a different PCM? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: swapping in a different PCM?
    dont they use the same sensors? so isn't it just directly moving the pins over to the new pcm?
    • #17
      not the same sensors/plugs for everything. Like for my ls1 maf with the built in IAT sensor I have a new plug adaptor that plugs into my harness and converts to the ls1/iat sensor plug. The wiring at the PCM might be seperated though so it might not matter
      http://www.bowtiev6.com/
      • #18
        I see...well, if I am able to run both pcms simultaneously, maybe I'll get lucky with most connections and be able to leave the pins that aren't 100% compatible with the 4.3l in the 3800 pcm.
        Actually I really just want to do this so I can SD tune...so really if I am able to just swap the necessary sensors from a 4.3L over to our car, and piggy back the 4.3l pcm enough to get access to the tables necessary....thats all I really need...
        • #19
          IM a little lost at this point as to what you're wanting to control that HPT doesn't have on it....
          1995 Pontiac Firebird
          • #20
            MAP tuning (or what they call speed density tuning)...we don't have the additional open loop/ve tables for it, so you kind of have to cheat to do it.
            So far I have cheated by commanding more fuel in PE mode, AND I've set my injectors to 31 # instead of 32-33 where they should be (so that they pulse faster) as I am leaning out under WOT in the upper rpm band. I plug in my afr error % into the VE table, but the maximum number we can input into the table is 200% and I have maxed this number already in all the WOT (100Kpa) cells.
            I believe that the 4.3L has alot more tables then we do, and is capable of speed density tuning (I think).
            Since in the upcoming next few months I will no longer be able to run a maf, I absolutly 100% need to tune via the MAP, so I am trying to find solutions that do not involve spending ridiculous amounts of money on a standalone, especially since I have already invested in hp tuners...
            • #21
              for radical builds hptuners still lacks needed tables for our 3.8 cars. Hptuners is fine for 90% of the 3.8 crowd, but those that have one off setups or big turbo builds need more. Band-aids have got people by so far, but there has to be a way to unlock more
              • #22
                hp tuners has no idea of the interchangability however the guy said that the 4.3 is Exactly the same as an LS1 pcm...they even have the same operating system
                • #23
                  interesting...
                  now for the pinouts of each...
                  which 4.3 is the same? Like what kind of vehicle and year
                  • #24
                    I know what you wanna do, I had the same thing. this is what I would do, however dont know if its doable, and i dont know if its worth the hassle.
                    the ls1 pcm drives individual coils, you could set your system to have ls1 coils and screw the ICM board, however I dont know if you can tell it that not to fire 7 & 8.
                    best bet would be a stand alone and piggy back it on. OR an LS1 AEM EMS, and you can do alot with that, but still repinning everything, and still swapping out to 6 coils.
                    in the long run. its gonna be alot of work and money.
                    • #25
                      Originally posted by 97rs4life View Post
                      interesting...
                      Not sure, I will fire off another email to Hp's support now.
                      See I'm curious that you can make a stand alone piggy back on our pcms, but how about making the 4.3L piggy back on our pcms instead? I mean if it works it is far cheaper?...I don't want to go standalone because it costs more then I want to spend at the moment, especially if I can get away with being able to piggy back a 4.3 pcm...
                      How do you piggy back a standalone on our pcms?
                      • #26
                        this is why I am far more trusting towards a standalone system when doing a high power/expensive build. I don't think its worth cheating if you have to grossly overdo it just to compensate for a limited amount of variables.
                        • #27
                          pretty much you run what ever sensors you need into the stand alone and have the stock pcm control trans, and your gauges. everything else stand alone. well since I am unaware of a standalone that will work with our ICM board you can have the stock pcm fire that as well. as far as fuel/ injectors and other boost sensors goto the standalone.
                          simple terms
                          (stock PCM)----- {stand alone}-------- fuel injectors------- pressure sensor
                          (stock PCM)------- trans
                          (stock PCM)-------- gauges
                          (TUNED stock PCM)--------- ICM board-----coils
                          now this is just a simple one and I may have forgotten something.
                          come to think about it a Gready E-manage with a boost sensor might help you.... maybe
                          but hp tuners + an E-manage= 900ish maybe
                          a new AEM 30-1040 Engine Management System is as low as 1000.
                          • #28
                            simple terms
                            Ok, I don't quite understand (maybe because I haven't looked at the actual installation of a standalone) but can what you just explained above not be done with another seperate pcm out of another car rather then a standalone?
                            • #29
                              How are you going to tune both pcms through one OBDII port?
                              • #30
                                If this post can evolve a little bit on this, Id like to actually make it a sticky. Keep it going, its peaking my interests as well....
