Swapping in a different year PCM into a 99 car? - FirebirdV6.com/CamaroV6.com Message Board
  • Swapping in a different year PCM into a 99 car?
    so heres what im trying to help a friend out on. he has a 99 camaro, auto, 3.8...i got him a 98 firebird pcm auto, 3.8. should that do the trick? he has a bad pcm. also how hard is it to swap? couple bolts on the passenger side, right?
    Re: Swapping in a different year PCM into a 99 car?
    There are going to be a few conflicting problems. Your friend's '99 is a drive by wire car and uses a different throttle body, intake, pedals, and of course, PCM. The '98 PCM came from a car that was drive by cable and therefore has a different throttle body with a throttle cable (instead of electronic throttle), angled intake (as opposed to the 99-02 straight intake), and different pedals. There also might be a few other little differences between the two.
    IMO, you'd be better off finding a same year PCM for your friend. If you don't want to mess with an aftermarket replacement, then try searching on Craigslist, Ebay, or here.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
