So for the past 2 days my wideband has all of a sudden gone wacky on me. It seems to be reading between 10-12 afr all of a sudden, while the narrow bands seem to stay up at 700-800mv, which tells me I am not in the 10-12 afr range. Then all of a sudden the wideband will read fine again, then not, then fine, then not...what do you think can cause this? It is an AEM UEGO wideband that is not even 2 months old...Please don't tell me I just puked out another wideband...I just finished eatting 2 LC1's prior to this AEM...
intermittent wideband
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: intermittent wideband
If it is bad just go with a PLX, I have had mine for about 9 years with no problems, knock on wood.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
AEM was supposed to be good...I don't want to go through yet another wideband...in less then 2 years I will almost have bought enough widebands for individual cylinder tuning, but still not of been able to do it...
PLX all the way, I'm still on the same wideband sensor also , so I have got my moneys worth out of my wideband, plus Hptuners has the PID for it and it is easy to get it right on the money.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
im wondering if the fact that I am burning oil is killing the sensors on me...
If you burning oil or running too rich your sensors are going to be shot.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
there isn't really a way for me to stop burning oil though...am I just totally screwed then? my narrowbands are stock with 240,000 km on them and they are still fine?
Originally posted by Blizzard242 View PostThe best thing you can do is mount it as vertically as possible. Just so junk doesn't sit around in the sensor. Have you tried installing it temporarily into the headers?
Originally posted by Blizzard242 View PostYou mean one of those heat sink deals? I need to look into something like that for myself.
Q: How do I make a heat sink?
A: Take a 4-5” square piece of copper (optimal) or aluminum, and punch/drill a hole just big enough to fit over the threads of the O2 sensor. Bend it so that there are two “wings on either side of the sensor. Mount the heat fin between the sensor and the sensor washer. We recommend 0.0647" thickness 4" x 4". (Or you can buy the Innovate HBX-1).
Or the actual Innovative HBX-1 looks nice.. But expensive.
http://www.innovatemotorsports.com/x...8&cat=0&page=1
TEAM C6V6
Copper should work great, I could see if you were runnning a turbo to do it, but N/A just put a spark plug heat cover on it and be done. I would also make sure you CAT isn't clogged and causing your wideband to heat up too much and making it burn out, I don't run a CAT so I haven't had any problems like that. Or go with a PLX.:D08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
cats brand new...that copper thing is ridiculously expensive...its basically just a copper washer...take a couple pennies and drill holes through em ...holy sh*t
Originally posted by LETZRIDE View Postcats brand new...that copper thing is ridiculously expensive...its basically just a copper washer...take a couple pennies and drill holes through em ...holy sh*t
TEAM C6V6
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...18 hours ago
