Im getting the p0102 code, which is low MAF frequency, i have borrowed a friends throttle body/maf and i am getting the same problem, any ideas?
p0102
Re: p0102
you are running the stock 3.8 maf in the tb correct? If so you can actually run open tb if you wanted to and it would run. So a ghetto intake shouldn't do it
Re: p0102
in the scanner what does it say about your MAP? Is it giving you readings for that?
Re: p0102
it reads the map, on a cold start it started around 44.0 and as it warmed up it dropped to around 30
i noticed i had some more DTC's set to "no error reported" i turned those off and im going to re-scan the car and see if anything shows upLast edited by Fondle; 04-20-2010, 08:39 PM.
Re: p0102
re scanned the car, nothing else came up besides the MAF error, i do remember when i first got the car there was a resister on the IAT sensor, and i took it out and taped it up
is the iat sensor related the the maf at at? i notice they merge into the same wiring harness on my car, tomorrow i will check all the wires but its to dark right now
Re: p0102
nope they go to a seperate pin at the PCM. Just use the same routing
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 weeks ago
