Just ordered it today. Got the Stardanrd edition. Came out to $511.
Just ordered my HPtuners
Re: Just ordered my HPtuners
Ya. Ordered a 97 PCM also. But I am trying to find out if I am going to be able to just plug this up to the car and start tuning. Ive ran 97 pcm with no problems in the past. Its a 95 and im swaping in the 97 pcm.
Originally posted by Watazz View PostYa. Ordered a 97 PCM also. But I am trying to find out if I am going to be able to just plug this up to the car and start tuning. Ive ran 97 pcm with no problems in the past. Its a 95 and im swaping in the 97 pcm.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Whats your temp, where you live? I would say about 14-15 degrees timing at WOT would be alright , 120% your FMU hass maxed out your injectors which is to be expected, those 36LB injectors which are on their way you should be about 80% at WOT. I always noticed with my PD that it gave me falss KR since its bolted on the engine and has force pulling on it, thats when I desenitized my KR sensors since they are way too sensitve from the factory. The 05' Buick 3.8's like my Dads, they have the KR sensors turned down and timing raised from the factory so I guess GM learned about their false KR problems, they run about 28 degrees timing from the factory, this is a 05' Buick lasabre 3.8. For a 3800LB+ car with air leveling in the rear it def. gets up and goes and rides so smooth, if I could find a lower priced one I would buy one.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
current temp is 80-95 *F. So far ive just disabled torque management, speed limiter, and messed with the trans. Ill wait until those injectors come in and i get that WB installedto start with the fuel and timing.
