I want to install a knock gauge to monitor knock at high boost levels without bringing a laptop in the car.
The caspers knock gauge form a GN look slike a good candidate but it appears that to install it you need to tap into the ESC module (electronic spark control) and the gauge reads knock from the module.
Does the 3800 II OBDII even have an ESC module? Would this gauge be compatible?
Thanks guys
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Yes , just look in the wiring PCM diagrams in the Tech database and it will tell which wires are for the Knock sensors , theres 2 wires, I taped into them to lower desensitize my knock sensors. Or buy a Aeroforce gauge scanner and its like a mini HPtuners except for the tunning it part, has alot of scanning , clear DTC's and can do case learn's also.
Both , because if your getting KR on the side your not monitoring then you might pop a piston on the side your not monitoring.
