what could be causing this code? - FirebirdV6.com/CamaroV6.com Message Board
  • what could be causing this code?
    Code# P0137
    02 sensor
    Circuit low volts????
    If anyone knows that would be a great help!
    thanks all
    Re: what could be causing this code?
    bad o2 sensor
    wiring broken/corroded
    just to name a few
    http://www.bowtiev6.com/
      hmmm crap lol
      OK thank rs for the info. The weird thing is is the SES light doesn't come on all the time just every now and then..
        It's not meant to set, and stay on indefinately. If it passes the readiness check, it will not illuminate the SES light.
          weird....
          Would you know what 02 sensor that is setting off the SES light?
