P0420 - FirebirdV6.com/CamaroV6.com Message Board
P0420
  • P0420
    Hello All -- need some suggestions. the vert is throwing a code. P0420 "Catalyst Efficiency below threshold"
    Can you give me some ideas on things to check first. Is it obvious to check the catalytic converter? She's running ok, not missing as far as I can tell -- little hard to start this morning.
    We replaced the fuel pump and filter about 3 weeks ago. Any suggestions would be appreciated.
    Thanks, as usual.
    Carolyn
    2002 Camaro Convertible - Stock!
    Re: P0420
    How old is your converter? It's either the cat or the sensor afterward. My bet is the cat.
    Maryland has fairly strict inspections too, don't they?
    Lounge Moderator
      Re: P0420
      converter is as old as the car....2002 with 116K on it.
      In Maryland, you only have to have a vehicle inspected 1 time, unless you let your registration lapse, then you have to have it inspected again......
      On the Eastern Shore of Maryland, we are not required to have emissions inspections at all, I think.
        Re: P0420
        oh, the code says its a "bank One"
          Re: P0420
          I'm saying it's the converter then. If it's running well, you could always install a SIM to turn off the SES light.
          http://www.afterthoughtsauto.com/o2sim.html
          Lounge Moderator
            Re: P0420
            Swap it out with a hi-flow cat
              Re: P0420
              If I gut the cats and reset the code, will it come back on?
