desensitizing knock sensors - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: desensitizing knock sensors
    so whats my hardware look like lol?
    • #17
      Your hardware off the top of my head would be 4-6 resistors splicing the 2 KR sensor wires and running a ground wire , thats about it. I set my 2 KR sensor setups together and ran 1 ground off of them like YY , I think would have to go look at it. its been on there 10 years. If you go over 30 % I think it will set off a low KR sensor DTC. which is fine since it still picks up KR, mines at 40 % and will still see 4-5 degrees of KR and its still not audible. I have never heard audible KR from my car except when I first had my PD on my car and har my TRC-1 at 0 and got on it and heard the worst sound you can ever hear from a car a nd let off imediately. LOL So I know what audible KR is on my car.
      • #18
        do you have a picture of the piece on your car steve? What are you running the ground wire off of?
        • #19
          I run the ground to the ground wires by the batt., I'll see if I can get a pick.
          • #20
            I need to do this on a 99. Time to re-learn my digital electronics class from 9 years ago. Unless the values end up the same.
            • #21
              No this works pretty well, been running mine for I think 6-7 years now at 40% desenitized in this AZ heat, I bet I would dyno around 220 WRHP+ with the VS cam, so I know it works well my Dads 05' 3.8 Buick Lasabre has more timing in its cells than mine, so I think GM figured it out, my Dad always told me the 3800's had alot of false KR, working 40 years for them I guess he would know. hit me up with a email so I can send you the intruction sheet and program.
              • #22
                Hey guys, could someone that has a copy of the software (knockit.exe) please send it to me (pm me for email). I'd really appreciate it. Steve is experiencing some technical difficulties sending the software to FirebirdGT and myself. If I can get a copy I can just permanently host it for everyone.
                • #23
                  x2...does anyone know the size of the resistor to use in order to reduce the knock sensors by 40%???
                  • #24
                    Instead of posting a new thread, I found one with the title and some info on what I want, back from the dead lol
                    So Alex and I were tuning on the bird last night and had a serious issue with KR. I was getting 15* of KR, but only in first. I could downshift into second and nail it and only see maybe 5* tops of KR. I have two questions
                    1) does this sound like false knock to you? Could this be caused by the fact that I have a 99 PCM in my car that is a 2000 (maybe the sensors are mis-matched to the PCM?)
                    2) I would also like to know about desensitizing by 40% as well.
                    Team NoVa
                    • #25
                      Sounds like its false, I have the instructions and program but like I tried in the past it won't send the program through when I email it to you. FirebirdGT has the instructions and program as well. Maybe he'll have better luck emailing it to you.
                      • #26
                        I had the program sent to me awhile ago and wrote down some of the numbers. To desensitize the knock sensor by 40% you will need to install a 1,560 ohm resistor at R1 and a 13,650 ohm in R2. I have resistor numbers from 5% to 50% if any one is interested.
                        • #27
                          so is this really a common thing for 3800 series II motors?? i've always had quite a bit of KR no matter how much timing i pulled. i'm going to put some race gas in my car, when its back up and running to see if its false or not... but desensitizing our knock sensors is pretty common? and safe?
                          • #28
                            Works on my 96' for about 10 years now, it will still read KR if any is there.
                            • #29
                              Hehe yeah it was worse when I put my longtube headers in. Used a little dynomat around the sensors and that cut it down a bit. Still get some false KR though, nice post!
                              • #30
                                i've put dynomat around atleast one of my sensors.
                                when you guys have what you believe is legitimate knock. do you hear it? because i've never heard any in my car. but see it on the scanner.. my car is down for a bit and i'm gonna try a few more things. but really curious on that. one of my manifolds is a pretty crappy log. and the other side is the gtp mani... and alot of grandprix guys say that the first thing they upgrade to reduce KR is manifolds.
                                • Manimal
                                  Coil springs
                                  by Manimal
                                  3 days ago
                                • Manimal
                                  Newby here
                                  by Manimal
