Aviation gas bad for O2 sensors? - FirebirdV6.com/CamaroV6.com Message Board
  • Aviation gas bad for O2 sensors?
    Hi,
    I have a friend that works at a local airport and has access to 130 octane aviation gas. He uses it in his 67 camaro and 77 skylark and it smells awesome coming out the exhaust. Will this stuff kill and O2 sensor? I think it has a lot of lead in it.
    Thanks.
    Re: Aviation gas bad for O2 sensors?
    using 130 octane gas in a 4th gen camaro is just plain dumb. not to mention it is going to kill your cat and o2 sensors.
    im not even sure if it will run properly.. my guess is you would see a ton of backfiring and unburnt fuel coming out of the pipes
      Originally posted by Rhunadan View Post
      Hi,
      Thanks.
      Can't use leaded gas in an unleaded engine, the lead deposits that build up would be a bad thing for it, not to mention the cat would be clogged pretty fast, and youll kill the O2s
      1995 Pontiac Firebird
        Hmm that **** has like 10 times the amount of lead than regular leaded gas ever had. I really doubt your cat, spark plugs, o2 sensors will be very happy. Not to mention that you won't gain anything except for that awesome smell, which is probably toxic.
        Oh, I think it's also a federal crime.
          I believe that it is a federal crime and you will probably wind up going to jail. Don't drop the soap..
            Wait.. you live in Canada and I don't know the laws of the land regarding that sort of thing.
              They would have to prove its aviation fuel before anything.
              I dont think the plugs and sensors would like that stuff too much...highest I have run on the car was 110 mixed with 94. (remember unless you put the stuff in with a bone dry tank, it will be diluted)...I think I was somewhere around 104 from my guestimate.
              I would look into maybe getting your hands on some 110 Tony if you want to maybe run some more timing or something.
              Without upping your timing you will not see any improvement with using a higher octane fuel unless you are already getting lots of knock...
