When I purchased my car, the light was already on. The previous owner informed that I needed the sensor which I believe is under the seat?? Can someone point me in the right direction as to where I can buy the sensor and how to replace it?
IIRC, you need either the Airbag SRS Module replaced or the clock spring behind the steering wheel is broken. Module will need to be replaced if the car has previously been in an accident that resulted in blown airbags. Clock spring can go bad or be broken if the steering wheel has been turned with the steering rack removed.
'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Just cover up the SES light and be done.LOL I'm thinking of going with a Grant or Spearco steering wheel and taking out the air bags of mine, my whitegauge overlay covers up alot of the airbag code, plus it a non emission code so it can be on when you go through emissions and still pass, here in AZ anyways.
My airbag light had been on for quite awhile...Then I looked at the fuses and found out that the airbag fuse was missing. I popped a new fuse in and the light was gone.
Yeah, that could work but I wouldn't even know where to look to find that or even how to install it. Does anyone know where to download a factory service manual?
The steering rack was disconnected and I'm sure the wheel had been turned w/out it being hooked up. Like pace was saying, I think mine got messed up that way.
