So I tightened the belt up today and then I began to run lean. So I took the car out for a scan and my injector duty was at 120% !! I'm only at 7lbs but I think it may be the tune.maybe I just need to adjust the PE tables. But has anyone maxed the gtp injectors out on7 lbs with the pd?
36lbs maxed??
Re: 36lbs maxed??
Hotwire ups the voltage under WOT so the volts don't drop, I think you should be fine with your 36LB injectors and a Walbro pump since the Walbro will up your fuel pressure about 2-4 PSI. Also you said you redid your PE , so you might just need to redo your fuel tables to get the right #'s . You should be about 11.5-11.8 under WOT to be safe.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 36lbs maxed??
I changed the add vs rpm table. I actually went to the initial one you sent me about a year ago steve, just changed a few things. I initially change the tables frome those pretty dramatically because off the trans slip.
Re: 36lbs maxed??
Originally posted by Watazz View Postits a 95, with the 97 PCM thanks
That will help :tup:
Injectors:
http://www.racetronix.biz/itemdesc.a...1D030x&eq=&Tp=
