ODB codes giving me troubles again - FirebirdV6.com/CamaroV6.com Message Board
  • ODB codes giving me troubles again
    Ran the scan, and came back with 4 codes now.
    DTC P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
    DTC P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
    Seems very contradictory to me...
    DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
    Those 3 are all from the post cat sensor right? Because I simply don't have that one in the car.
    DTC P0153 HO2S Slow Response Bank 2 Sensor 1
    And this one is the passenger side manifold right? I have a replacement just gotta make sure it's the right one. I don't understand the whole bank 1/2 sensor 1/2 system....
    Any help?
    (Genius self spelled OBD wrong....)
    Re: ODB codes giving me troubles again
    Sensor 2 is always the post cat sensor. remove the codes via HP tuners or put the sensor back. Bank 2 is the passenger side, bank 1 drivers. Slow response generaly means the sensor is going bad.
      Alright... I'll put in my spare tomorrow. Thanks :)
        Had P0138 pop back up today, even though I have a simulator in there... have to check that out.
        The trouble this time Is coming from P0650. Which from what I can tell, says the malfunction indicator light, is malfunctioning. Wtf. What even is... my SES light is broken?
          One would assume so
