Not having the MAF screen in place will cause the MAF to have erratic readings. I would put that back before i bought a new MAF sensor.
I would definately like to try that, but nobody seems to carry it. Autozone/Checker don't have them at all, and from the dealership you have to buy the entire MAF assembly, which is $360.
So I just replaced the pump. I had one that I bought off ebay a while back cause I wanted the sender from it (it's from a WS6 and somebody on here said it's the exact same pump.) The guy didn't guarantee that the pump was good, just the sender. That's why I didn't put it in in the first place.
I decided to take a chance on it anyway. Now I have 65 psi at all RPMs!! Is that too much? Will it hurt anything?
Hopefully somebody can respond quickly, so I can put it back together.
A side note from the above post:
The pump from the WS6 is definately not the same as the original. The actual size of the pump is larger in diameter by at least 1/4 inch. The assembly is also different to accomodate the larger pump. Even the electrical connections are different. I will post a picture of the two side by side later on. Everything on the outside is the same, though.
Also - My SES light has turned off, and I didn't even reset the computer.
* As promised - Here is the picture of the two pumps. The left pump being from the WS6.
And the right pump being the original. Both are Delco pumps (sorry, I didn't get the part numbers off them.)
Should make you run on the rich side but not really hurt anything. I Have the Racetronics LS1 pump in my car and the fuel pressure is fine. I would suspect your regulator is bad or the vacuum line is off of it.
So after driving the car for a few days, the P0171 and P0174 codes have not returned
since swapping the fuel pump. Now I am getting another code, though.
But this time, it's the code I was expecting after installing the new cat.
It is DTC P0420 Catalyst System Low Efficiency.
Guess I'm gonna have to get that O2 Sim after all.
