My 99 FB has stated putting out a P0102 code. I checked it at work with our scanner and see that it relates to the MAF sensor. Resetting the code only lasts for a little while before the SES light is back on again and the code is back. My mechanic suggested I try cleaning the sensor by spraying some contact cleaner air intake housing after the car has cooled down. I notice in some other threads on this that it's suggested the MAF sensor be removed and cleaned. Where is it located and how hard is it to remove?
buy a can of CRC mass air flow cleaner.. (autozone 7$) unbolt the 2 bolts that hold the MAF to the TB don't touch but hose the actual sensor down with the cleaner.. then your done.
