Does entering 0 for the first value in the PE enable TPS, put the csr in PE? If not what so I need to change to get my cruise afr to 14.7 with closed loop disabled?
Forced PE
Re: Forced PE
I would try like 10 in the TPS then once your foot is on the pedal it will go in PE mode. If thats what your looking for.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Forced PE
I entered the first few cells in the PE enable TPS to 0. Now I can use PE to tune for my cruise. Idle is a little rich 13.9. However my cruise is 14-14.7 and doesnt move around much at all. I had so much trouble with this cruise AFR now I can say I belive it is fixed.
Re: Forced PE
yea ignore the negative sign ;) Just a fluky thing with our cars. lol If it bothers you, you can make a custom pid to get rid of the negative sign.
Re: Forced PE
physical education.
POWER ENRICHMENT
:D
Re: Forced PE
If its your O2 sensor off the car then , yes its your O2 sensor.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
