The best i remember when i last tuned my maf With the stock injectors i had good fuel trims. Now using 42lb green top ford injectors which I believe are 45 on our rail. I hafta set them to 39lb have acceptable trims and it's still around a positive 10 ltft. Any ideas? Should I use the 42? And maf tune?
Help tuning with 42lb injectors
Re: Help tuning with 42lb injectors
You should use 42 and scale them, then use PE to dial them in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by thebeewantsboost View PostThe best i remember when i last tuned my maf With the stock injectors i had good fuel trims. Now using 42lb green top ford injectors which I believe are 45 on our rail. I hafta set them to 39lb have acceptable trims and it's still around a positive 10 ltft. Any ideas? Should I use the 42? And maf tune?
TEAM C6V6
Eh.. Don't worry about tuning till your build is done or you'll really just be doing it all over again.
PS.. I have lucas 42.5 injectors and they were a ***** to figure out. I ended up setting them all on a straight line at 42 or somewhere around there and did a MAF tune. I don't feel like that's the right way, because the injector table isn't really suppose to be tuned. I'm pretty sure your injector table should be a fixed thing and you tune the MAF and PE from there. I really couldn't find any good help on those specific injectors.
TEAM C6V6
I set my green tops at something like 44.5 across the board on the injector table, whatever it is that the calculator in HPT tells you to enter them as when you enter the rail pressure @ a certain rating for our fuel rail pressure.
Having said this, in my research I found that up to '97 this was the proper way to do it, and from '98-'02 you were supposed to scale them to correspond with the MAP sensor readings...(I think). SO since I'm a '97 this should be fine, and I know absolutely nothing as far as scaling goes. BUT I think turbov6camaro's website tells you how to scale them.
This thread on 'Tech should help anyone who needs to scale their injectors: http://ls1tech.com/forums/fueling-in...ump-chart.html
Your doing it right , tune for your motor first then save it , then do boosted so you have a back up file just in case.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
