I built a set of true duels and i am ordering a wideband. I was just wondering where is the best place to hook it up. i know that it doesnt matter what side just asking how far away from the header flange if it matters how close it is
Wideband on true duels
Re: Wideband on true duels
I would put it about 1-2ft from your O2 sensor.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I think the only seperate cylinder tuning you can do with HP tuners is to skew the injectors, and I can tell you right now you won't need to do that.
It sure would be nice though cause if you have a bad injector somewhere you could eliminate 3 possibilities when trouble shooting.
When you're tuning however, you can use the stock o2 sensor locations, so really for a permanent location I would only install a bung on one side.
TEAM C6V6
it would be good to have a bung on each side so you have the ability to see how each side is doing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
