What is wrong with my bcm? - FirebirdV6.com/CamaroV6.com Message Board
  • What is wrong with my bcm?
    I re-soldered the pins on it I wanna say 2 years ago, then it started acting up about a month ago. I re-soldered it again and it looks better than the last time I did it, and its acting up again already. Do I just need to buy a new one?
    1997 Chevrolet Camaro
    L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
    Re: What is wrong with my bcm?
    Yes! Same thing happened to me.Don't wait till it leaves you sit like an asshat in the middle of the road.
      are you soldering correctly? or are you getting a bunch of cold joints that just look pretty?
      cold joints just lead to problems so its possible that maybe you arent doing it correctly?
        That could be the case, I've never soldered anything other than my bcm before.
          try putting the gun on the solder point and holding it there until the existing solder melts, add some solder but don't let it touch the gun, let it melt on its own when it gets hot enough touching the point desired, just keep the gun touched to that desired point, never touch the solder itself or you will get a cold joint.
            Yeah I tried to just re heat the points and that wasn't really working out. So I touched the solder to the iron and it'd melt off into a ball then id melt that ball onto the pin
              My Hptuners stop working
              Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
              13 hours ago
            • Money pit
              Zzp cams
              by Money pit
              Has anyone used zzp gt1 cam if so is it worth the money and time
              2 days ago
            • thatpewterfirebird
              2001 3800 s2 firebird
              by thatpewterfirebird
              4 days ago
            • Turbo 3800 camaro
              Where are the videos?
              by Turbo 3800 camaro
              Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
              6 days ago
              New Chevele
              Just saw it on Facebook, looks awesome. The front and rear nice looking....
