KR at launch - FirebirdV6.com/CamaroV6.com Message Board
KR at launch
  • KR at launch
    if i punch it from a slow roll in 1st i can run through the gears with no knock. however. if i make my tires spin or get wheel hop. i'll have knock all the way through the gear. were talking 6* what can i do?
    it definitely seems like false knock. is there any reason it would be real? i didn't have the issue before i turbocharged my car. it has custom made ffh to the turbo and new exhaust to the back of the car under the k member. no flex pies or anything. i also have a 6 puck clutch.
    http://www.hptuners.com/forum/showthread.php?t=36939
    Re: KR at launch
    Looks like your commanding alot less timing when you ease down on the throttle compared to when you lunch from a dead stop.
      Re: KR at launch
      were u looking at timing advance?
        Re: KR at launch
        yes...
          Re: KR at launch
          my high and low octane timing tables are borrow from a supercharged buick regal. but i'm thinking i may have missed a table? does the max torque timing table need to be altered?
            Re: KR at launch
            no......
              Re: KR at launch
              could you be a little more specific for me?
                Re: KR at launch
                Did you compare the the acutal timing to the knock retard for both lunches? I can't look at the scan at work but from your dead stop you had 6* retard and the timing was stiil up at 13* . Your roll start you had no retart and your timing was lower than 13*. I woud sat that means you were trying to comand 19* from a dead stop.
                  My Hptuners stop working
                  Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                  13 hours ago
                • Money pit
                  Zzp cams
                  by Money pit
                  Has anyone used zzp gt1 cam if so is it worth the money and time
                  2 days ago
                • thatpewterfirebird
                  2001 3800 s2 firebird
                  by thatpewterfirebird
                  4 days ago
                • Turbo 3800 camaro
                  Where are the videos?
                  by Turbo 3800 camaro
                  Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
                  6 days ago
                  New Chevele
                  Just saw it on Facebook, looks awesome. The front and rear nice looking....
