Replacing MAP sensor? - FirebirdV6.com/CamaroV6.com Message Board
  • Replacing MAP sensor?
    How do i replace it? tools needed and about how long to replace?
    Re: Replacing MAP sensor?
    I remember it is pretty easy.
      MAP sensor? No tools really necessary. It clips out of the bracket and also the harness. Bring some band-aids as the cowl will probably try to eat you alive.
        First, disconnect the neg. part of your battery. THe MAP is located on the passenger side almost at the very back. Disconnect the wire and if I remember correctly you tap on the locking tabs and you pull up. I don't remember if you would have to use a skinny flat head screw driver.
          thanks guys did it today unfortunately it didnt resolve my problem
            Did you ever replace the coils?
              Dude. Bring it by one day and I'll get you squared away. Preferably a day with no rain or snow. Let me know if you need my # again.
                yea coils icm and now map lol its like troubleshooting this thing one by one....yes # again please def would be a great help id appreciate
                  why did you replace the MAP? If anything you'd replace your MAF first. Unplug your MAF and drive around and see how the car feels.
                    Do you have a SES light on? Get a cheap pocket scanner and scan that so you don't waste anymore money.
                      He's going to run around in open loop.
