I put a high flow cat on the other day, and now my service engine light is on. What do I need to do to get it off?
Check engine light
Re: Check engine light
I know this is illegal to put on a street car, but it sounds like it would work
http://fasttoys.net/shop/product_inf...e1e9f25ce4773e
People use that or just tune them out with Hptuners. Not uncommon.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I may be wrong on this, but as I understand it, our cars only use the downstream "after the cat" O2 to determine if the CAT is working or not, lean/rich is solely controlled based on the O2 sensors before the CAT.
As far as inspection goes it varies based on where you live, if they put a sniffer on your car it may not pass at all with the high-flow, just depending on how much they are checking for. if they do a visual inspection and notice the sim they may fail you, if they just check for DTC's you should be fine.
Tunning is your best bet.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
420 is the post-cat O2 sensor... it's probably the single most common OBD code. The sensor is bad, not your cat most likely. I mean it could be your cat, but the sensor is a ton cheaper and easier to replace.
Good point, I would think that a properly working hi-flow cat should still enable the car to pass an emission check, and also not set off the post-cat sensor. If it cannot do that, they shouldn't be selling it.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
