Check engine light - FirebirdV6.com/CamaroV6.com Message Board
Check engine light
  • Check engine light
    I put a high flow cat on the other day, and now my service engine light is on. What do I need to do to get it off?
    Re: Check engine light
    I know this is illegal to put on a street car, but it sounds like it would work
    http://fasttoys.net/shop/product_inf...e1e9f25ce4773e
      People use that or just tune them out with Hptuners. Not uncommon.
        I've got a sim... works magic.
          Cool thanks, I'll get the sim, much cheaper solution. I'm assuming you still pass inspection with the sim? Oh, and is there any effect on the car if I don't get the sim in the next couple weeks?
            Not sure about inspections... but the only effect you're going to notice is gas mileage. And it will run lean/rich. And you can find a sim cheaper than that, jus'sayin.
              I may be wrong on this, but as I understand it, our cars only use the downstream "after the cat" O2 to determine if the CAT is working or not, lean/rich is solely controlled based on the O2 sensors before the CAT.
              As far as inspection goes it varies based on where you live, if they put a sniffer on your car it may not pass at all with the high-flow, just depending on how much they are checking for. if they do a visual inspection and notice the sim they may fail you, if they just check for DTC's you should be fine.
                I think I'm just going to go ahead and get a dyno tune instead. I have a few things done on the car and I would rather make sure I pass inspection and get everything done right.
                  Tunning is your best bet.
                    How do you know the code requesting the MIL was caused by the change to a high-flow cat?
                      I had my codes scanned and got this code, P0420. Which is the oxygen sensor that monitors the cat saying that it is defective or bad.
                        420 is the post-cat O2 sensor... it's probably the single most common OBD code. The sensor is bad, not your cat most likely. I mean it could be your cat, but the sensor is a ton cheaper and easier to replace.
                          Good point, I would think that a properly working hi-flow cat should still enable the car to pass an emission check, and also not set off the post-cat sensor. If it cannot do that, they shouldn't be selling it.
                            I talked to the shop that put it on, and they agreed to buy and replace the O2 sensor for free. So hopefully that's the problem.
                              ^do you have a hi flow cat? Have them move the 02 bung further down the exhaust towards the axle
