MAF error% histogram not working - FirebirdV6.com/CamaroV6.com Message Board
  • MAF error% histogram not working
    Do i have to have my Wideband linked to my hptuners? it is just a gauge glowing in my face right now. i am trying to figure out why when i hit start scan my maf err% histogram goes blank and says the message below. am i needing to add or delete things from other displays?
    This Histogram is not supported with the current loaded parameters.
    If this Histogram references Tables, it is possible that the vehicle
    you are connected to does not support these Tables. It is also possible
    that the sensor required for the Table is not found in the loaded
    parameters.
    If this Histogram references Sensors, it is possible that the sensor
    required is not found in the loaded parameters.
    If this Histogram references PIDs, it is possible that the PID required
    You will find all of your loaded parameters located on your Table Display.
    To add more parameters, right click the table display and click insert.
    For example, if you have a histogram built that maps Timing Advance
    and you do not have Timing Advance inserted on your Table Display,
    the Histogram will not function.
    Re: MAF error% histogram not working
    Hello again. You have to make sure you're logging the MAF and EGR in the config. What are the steps you've taken so far to get this going?
    TEAM C6V6
      ok i will figure out how to attach the WB to the EGR can i run the cable from the WB to both the gauge and the EGR.
        lol, I think I just addressed this on the other thread. If you keep your EGR connected you'll be getting voltage readings from the EGR and the wideband so your scans will be incorrect. I think that's what you're asking..
        TEAM C6V6
