Lots of kr - FirebirdV6.com/CamaroV6.com Message Board
Lots of kr
  • Lots of kr
    Hey guys over the past few days i noticed the car kind of struggleling while cruising so I decided to plug in HP tuners and do a quick scan, to my surprise there was a lot of KR when it was hitting 15+KR the car would struggle, the only thing I've messed with was with the Spark Advance and even then at the time i had 3KR tops, So after the scan I loaded up the stock tune because I thought I messed up tuning it, but i Still had KR going up to 15+
    What do you guys think would be causing this?
    fuel pressure is at 45 psi at idle
    only check engine code is P0341(Camshaft Position Sensor Circuit Range/Performance)
    replaced sensor itself and still has code
    checked the pigtail of the cps(cam position sensor)
    which was good
    | 6.67v || ground || 10.88v |
    Ive got a log i can email, I couldnt upload it here...
    Re: Lots of kr
    The 100* temps.
      Re: Lots of kr
      shouldn't think it would affect KR but is a case learn necessary after replacing the cam shaft sensor on our motors? but yeah the weather is gonna make a difference you should pull timing vs your iat.
        Re: Lots of kr
        Are you misfiring? Do you have a bad exhaust leak? Is something smacking the motor? All the above can cause KR...do you have knock?
          Re: Lots of kr
          No misfires, no exhaust leaks, there's nothing loose so I dont think anything is hitting the motor. If I go wot I get 3-4 kr through the rpm range not like the 15+ I get while driving
            Re: Lots of kr
            Sounds like a bad PCM.
              Re: Lots of kr
              if the car doesn't have misfires, what do you mean by it struggles?
                Re: Lots of kr
                Like when I try accelerating It feels like it has no power like when my cat was clogged(don't have a cat anymore), it just doesn't want to move and this is where 15kr+ Is built up
                  Re: Lots of kr
                  Ohm the knock sensors.
                    Re: Lots of kr
                    i'm not sure what 15KR feels like...i mean, the computer is pulling alot of timing, i could see that feeling like a brick wall... so... check knock sensors for sure.
                      Re: Lots of kr
                      Alright anyone know what the voltage is supposed to be for the knock sensors?
                      Incase the PCM is bad I just got one from a pick and pull .-.
                        Re: Lots of kr
                        i dont have a definitive answer for you, i can tell you that a knock sensor is a piezo electric sensor that creates its own voltage. its AC voltage, that i believe is measured in milivolts. i'm not sure if the normal reading is 0VAC or if there is a reference voltage though. i'd be interested to know myself.
                          Re: Lots of kr
                          There is A 5 VDC reference single through it.
                            Re: Lots of kr
                            Watch this.
                            http://youtu.be/vqj2YWbedsc
                              Re: Lots of kr
                              Cool ill check it out when I get out of school & work!
