Hey guys over the past few days i noticed the car kind of struggleling while cruising so I decided to plug in HP tuners and do a quick scan, to my surprise there was a lot of KR when it was hitting 15+KR the car would struggle, the only thing I've messed with was with the Spark Advance and even then at the time i had 3KR tops, So after the scan I loaded up the stock tune because I thought I messed up tuning it, but i Still had KR going up to 15+
What do you guys think would be causing this?
fuel pressure is at 45 psi at idle
only check engine code is P0341(Camshaft Position Sensor Circuit Range/Performance)
replaced sensor itself and still has code
checked the pigtail of the cps(cam position sensor)
which was good
| 6.67v || ground || 10.88v |
Ive got a log i can email, I couldnt upload it here...
which was good
