I'm wanting to buy a programmer for my car this month and I was wanting to know which kind to get that is good quality, priced decent, and would work for my Camaro. I don't know if some programmers are only compatible with certain makes or if they are iniversal. $400 is my goal spending limit, but I'll put aside a little more if I have to. I would greatly appreciate the help.
Programmer for 98' 3.8L
Re: Programmer for 98' 3.8L
hp tuners is the best, if you know what your doing. it is a full custom tuning program much like a stand alone system (around $600). if your not looking to go that route hypertech makes a tuner for our cars and im running that currently (around $300)and pcmforless.com will put a "street" tune for even cheaper all you have to do is send your old pcm back to them (around $150 or so). pcm for less can tune more torwards the different mods that you have already done. if i knew about pcm for less when i bought my hypertech i would have chosen pcm for less.Last edited by madforce10; 09-07-2012, 11:37 PM.
Originally posted by pathology knight View Postthis might be a dumb question, but i'f you send a company your pcm, i assume you can't drive the car, right?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I've got an aftermarket air intake I made for it, then the whole exhaust is redone, and if its anything I got some NGK spark plugs and MSD wire about to be put on. I was looking around the other night and found the Jet stage 2 pcm for around $250, I didn't know if that was considered a programmer or not, I'll check into what y'all are suggesting though. I've heard the Diablo Sport and Bully dog tuners are good too, I just haven't found anything about if they're compatible with my car or not.
You won't find anything better than HPtuners.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostYou won't find anything better than HPtuners.
I just wish someone would figure out a way of getting a coil per cylinder and still allowing us to use hp tuners :(....well and a little more support from Hp tuners for our pcms would be nice.
Quick question, if I had a '96 engine equipped with a intake manifold and cam from a '98 engine would that also mean that my pcm should be from a '98 aswell? I know that they changed the intake a little bit in '98 so im assuming the pcms are different.
Any shared wisdom is appreciated.
