I need to swap my PCM out on my 96 firebird 3.8 auto i see from the sticky that i should be able to swap one in without reprogramming unless shift points are different. I am wondering those since i beleive the key has an imobiliser chip in it how do i program my key to the new PCM?
How to reprogram key?
Re: How to reprogram key?
You need a new key if replacing the BCM, if replacing the PCM you don't need anything if it has the same tranny and rear programed into it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
