anybody use this tiny tuner table? - FirebirdV6.com/CamaroV6.com Message Board
  • anybody use this tiny tuner table?
    anybody use this table from tiny tuner?
    Looking at it maybe the cylinder mass air vs rpm table would do it. never logged mg/cyl before though. just looking to see if anybody has inpit
    not a whole lot of info on what it does/how it works. but if it could enable PE by KPA that would be pretty awesome...Looking at it again, maybe the cylinder mass air vs rpm table would do it. never logged mg/cyl before though. just looking to see if anybody has input
    Re: anybody use this tiny tuner table?
    Do you have the proper bin file to use tiny tuner?
      The way it works right now is on TPS, TPS should correspond to KPA should it not, more or less?
        I do have the proper bin file, thanx
        with TPS, it works but i either go rich early or lean under certain loads depending on the settings in that table. it does the job but i was just searching for a way to stay stoich longer until i needed PE. say i'm in 4th gear and try to accelerate to pass somebody i won't go into boost but i will go into PE and command 11.0:1. its not a necessity, just wondering if its a possibility.
          you can control that with the delay table in hp tuners. put a few seconds delay for like 30-50% throttle, or whatever your average tps is under those normal passing conditions
            thanx good to know
              its how I get my Map tune to not act up. But I'll be going back to MAF shortly.
