Not shifting into 3rd gear at WOT - FirebirdV6.com/CamaroV6.com Message Board
  • Not shifting into 3rd gear at WOT
    So as the title says my 1996 3.8 Camaro wont shift into 3rd gear at Wot, it just revs until I let off. Shifts are set at 6000rpms, with the VS cam. Rear is 3.73s with 4l60e trans, right now I have shift set at 75mph running 275/40/17 tires. Any help would be appreciated, thanks
    So according to my scans it hit 73 mph at 6000 rpms so I changed it in the tune ,ill see if that works, got my shift points from a gear and rpm calculator so well see if its wrong.
      Got it fixed. Was the mph, so cant trust a gear and tire calculator.
        Had to do the same for 1st and 2nd was at 40mph and changed it to 37mph.
