Hi guys, I'm trying to help a fellow fbody v6 owner who has a 93 bird with an obd1 and has a ses light on. Once the scanner is plugged in the light continously flashes, instead of it giving a specific code or codes. I wonder if this is something serious.
Obd1 continously flashing
Don’t really know too much about OBD1 but on OBD2 it means bad misfire and need to get serviced immediately.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yes Cat related also , means get serviced ASAP.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Isn’t there specific scanners for obd I computers? Is yours compatible?
does the light flash with the scanner not plugged in? Are all the ground wires good in the car and to the port?
Have you tried reading the code like this instead of through your scanner?
https://www.obd-codes.com/faq/read-g...codes-free.php
the link in there has the trouble codes patterns as well
- 1 like
Yeah, obd1 usually gives out the code in 2 digit numbers once you plug in the scanner. I had an 86 fiero. So I was familiar with it, but this guy's bird just continuously flashes without codes. So I figured this is way more serious.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
