Code 34 - FirebirdV6.com/CamaroV6.com Message Board
Code 34
  • Code 34
    Every-time, I think I have the problem solved the code 34 pops up. Yes, I have changed out the Mass Air Flow Sensor and make sure the screen is clean and clear of dust. Is it a possibility that the cause is the Mass Air Flow Relay? Appreciate some help., this code is driving me crazy/.
    Make sure all vacuum lines don’t have a leak and the TB gasket is not leaking. You can check the vacuum with a gauge should be 20-22. Does it run rough?
