Terminology and Tables for beginners - FirebirdV6.com/CamaroV6.com Message Board
  • Terminology and Tables for beginners
    This is a compilation from hptuners, along with some basic stuff some might not know. If anything is wrong please correct me.
    These are basic things you will see in various tables
    MAF = Mass Airflow Sensor
    MAP = Manifold Air Pressure, measures in KPA
    IFR = Injector Flow Rate
    LTFT = Long Term Fuel Trims
    STFT = Short Term Fuel Trims
    ECT = Engine Coolant Temperature
    IAT = Intake Air Temperature
    KR = Knock Retard
    *IFR Table*
    IFR vs. KPA Vac: decreasing values makes the VCM think the fuel injectors are smaller therefore keeping them on for a longer period of time which increases fuel flow and makes the engine run more rich. Increasing values does the exact opposite. This is a good starting point for getting LTFT's slightly negative.
    Excellent writup on timing
    http://www.clubgp.com/newforum/tm.as...heck=735199779
    [ April 17, 2005, 06:38 PM: Message edited by: saltnvinegar6287 ]
    1996 white camaro M5<br />-Custom CAI, !MAF, !EGR, Hi-Flow Cat, Magnaflow Cat-back, Removed Jack/Spare/Back seats.<br /><br />2.12 60\' Best<br />15.14 @ 90 1/4 mile Best
    The ClubGP link is broken.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
