HP Progressive Tuner? - FirebirdV6.com/CamaroV6.com Message Board
  • HP Progressive Tuner?
    I saw this on ebay, the link is below or if you want just read the discription I have copied and pasted here.
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
    Is this a peice of junk or does this really work?
    Here is the discription from ebay
    The Progressive tuner simply wires into the factory socket already under the hood of your vehicle. Like the name suggests, you will instantly notice an improvement in response, acceleration, torque, and horsepower, or your money back. Don't be fooled into believing that expensive ECU units are the only way to safely and legally give your vehicle that extra kick!
    THIS IS NOT A CHIP!!!
    Once installed, locate an area near the drivers seat to adjust the tuner. When the tuners boost dial is low, you should see a gain of about 7-10HP and should get the same gas mileage as stock. When you turn the boost up, you should see a gain of about 15-22 hp. At full boost gas mileage will decrease about 2mpg but what will you care when your getting all the extra power!!!
    This is better than nitrous without The Nitrous effects on the motor.
    The Progressive Tuner simply wires into the factory harness of the IAT sensor. The module will work with the sensor to provide a new signal to your vehicles computer, or ECU. The ECU then adjusts your air/fuel and timing advance curves to new performance settings. Our progressive tuner eliminates costly parts and installation of ECU components (many ECU mods require you to solder and modify the main board), and still safely and legally provides the same end results. There is no risk of damage to the engine or electrical system since the modified sensor signal will always remain within the manufacturer’s recommended specifications. The Module works in conjunction with your vehicles ECU and will not affect engine reliability. Installation is very simple. All instructions are included and install should take about a 1/2 hour. The Performance Power Module can even quickly and easily be removed or re-installed at any time.
    Our products are backed by a 100% Lifetime Guarantee. If the kit or any component ever malfunctions, it will be replaced at no extra cost. No questions asked, no hassles!
    <a href=\"http://www.dontforgettotakeyourvitamins.com\" target=\"_blank\">www.dontforgettotakeyourvitamins .com</a>
    [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
    better then NOS [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
    dont get it
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      POS dont buy it
      00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
        thanks for the information guys, I'm in no way buying it [img]smile.gif[/img] but I do need to buy some kind of hp tuner :(
