ok read your drag post and saw you were running a dry shot, thought you swtiched to a wet shot
your like at 95%dc with those injectors at 5800 rpms
also since you are spraying a dry shot you would want to start your pe table at something like mid 11's not mid 12 which it probably about right now, so when you are spraying you arnt lean to begin with when the nitrous hits or atleast not as bad
us turbo people dont get the hit yall nitrous people do so we can start out a little leaner(mid to lower 12) and as we go add more fuel, you nitrous people need fuel as soon as you spray right now it looks as tho it takes a full sec for your fuel system to catch up after the nitrous hits.
either go with a wet kit or tune it to where your dumping more fuel when the nitrous hits
[ May 16, 2005, 03:45 PM: Message edited by: Drone51 ]
