WBO2 - FirebirdV6.com/CamaroV6.com Message Board
WBO2
  • WBO2
    id REALLY like this WBO2..
    http://www.innovatemotorsports.com/x...cat=252&page=1
    ..its really nice cuz i could put it right on my a-pillar..it records..and obviously..i could tune correctly with it..the only thing im not clear on is what actually runs to your PCM if this is plugged in to your O2 boss..i see this comes with its own O2 boss..so does that mean you put this into your exhaust and the stock narrow band remains to go to your PCM?..if so..where in the exhaust do you put it?..thanks!
    Yes, you want to keep your narrow band O2, I put my O2 bung right before the cat, about 8 to 12 inches away from it. Pretty much on the other side of the other narrow band O2 before the cat. A exhaust shop can put the O2 bung in there for you for $10 to $20.
      A wideband setup has nothing to do with your PCM. You would hook up the sensor before the cat and wire it up to a power source. You don't plug it into the PCM or anything (although it is possible to simulate a narrow band sensor if you need to).
      For example, I have the LM-1 kit. I inserted the sensor into the bung just before the cat (already had a bung with the Pacesetter headers). Ran the wires up into the car and hooked it up to the unit. Now I can hook a gauge up to the unit, or plug it into a laptop for readings. ;)
      And don't expect to get an LC-1 right away. They're new and are on backorder because of high demand.
      Matt
      1998 Mystic Teal Camaro M5
        awesome..just wanted to confirm..thanks for the info guys cuz this is next on my list [img]smile.gif[/img]
          Also, I'm not sure if that gauge is the exact one you want, but there's another one on there that'll save you a couple hundred bucks.
          http://www.innovatemotorsports.com/x...cat=250&page=2
          Matt
            that gauge is awesome too..but how will it save me a couple hundred bucks?..the LM-1 kit is $349 and the LC-1 WB Controller is only $199..do you mean that i could get that gauge and JUST get the LM-1 sensor cable??..that would rock
              You could get the LC-1 for $199, the gauge for $59, and the output cable for $8. Total price: $266.
              I got that gauge with my LM-1 kit, but I haven't hooked it up yet. For now, I just glance over at the LM-1 unit to see what I'm running (god awful rich). ;)
              Matt
                but in the ad it says "52mm, 8-18 AFR needle gauge driven by LM-1 analog output" ..so you're sure i COULD just use the LC-1 instead??
                  The analog output is the same either way. Notice the XD-1 gauge was made for the LM-1 also. LC-1 is the same as the LM-1, except there's no control box with it.
                  Here's the manual for the LC-1:
                  http://www.innovatemotorsports.com/s...Manual_1.1.pdf
                  Matt
                    oh ok..so the LM-1 basically just comes with a bunch of extra crap that isnt really required..i just need the O2, cable, and guage..too bad they're on backorder..thanks!
                      You need either the LM-1 or the LC-1.
                      The LM-1 is the standard one. It has a box that you can control the unit from, press a button to record, view the air/fuel ratio. A gauge or laptop is not required to view the current AFR.
                      The LC-1 is exactly the same as the LM-1, except the controls for the wideband are in the cable, not the control box. There's no buttons and no display. Because there's no display, you must either have a gauge or a laptop to view the AFR.
                      A wideband sensor by itself is useles...you've gotta have a controller such as the LM-1 or LC-1 to control it.
                      Matt
                        ahhh ok..what are the buttons it has though and what has to be "controlled"? ..would i have to get out of the car and push a button on the cable or something every time i wanted to view the current AFR?..or would it simply work like my current narrow band AFR gauge?
