Displaying histograms to delete KR - FirebirdV6.com/CamaroV6.com Message Board
  • Displaying histograms to delete KR
    "To fix your histogram problem. Delete "dynamic cyl air" from your config file in the scanner."
    ..how exactly do i do this?..im not sure exactly where in HP Tuners this is..and will it stay so i can read them from now on?..thanks!
    EDIT -- sorry..forgot to say this is using HP Tuners
    [ June 16, 2005, 04:31 PM: Message edited by: 1DangerousV6 ]
    Silly question, what exactly is your "histogram problem" ?
      they dont work..i only get numbers showing up in the first column..not all over across the board like they're supposed to..i guess im supposed to delete "dynamic cylinder air" as a pid but i have no idea how to do this..
        Open the scanner, pull up the table of pid's. The pid table is the one with 2 colums of data. On the right i think, there will be a pid called dynamic cylinder air. Mouse click on it and hit the delete button on your keyboard. Then save the config file so you dont have to erase it everytime.
        92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
          Thanks much Red ... I found it ... Scott, you find it? [img]smile.gif[/img]
            no..thats the problem..i cant find the table of pids..i cant find the chart settings or anything
            EDIT -- nevermind..got it!..thanks! [img]smile.gif[/img]
              i still only get data in the first column for KR in the histograms..will i have to log new runs before i'll be able to see this correctly?
                I dont think it will fix the old logs, you will have to get some new ones. [img]smile.gif[/img]
                  ok..i'll give it a shot..thanks! [img]smile.gif[/img]
                    tested it out..works great..now i can start removing KR..more power! [img]graemlins/rock.gif[/img]
